-17%
249 € 299 €
 [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3
[résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 Empty
MessageSujet: [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3   [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 EmptyMer 13 Juil - 20:56
BONJOUR A TOUS.
JE ROULAIS TRANQUILLE ET D UN SEUL COUP J AI EU UN BRUIT DE CASSEROLE EN PROVENANCE DU MOTEUR. J AI TERMINE EN ROUE LIBRE CAR J ETAIS A 200 M DE CHEZ MOI.
STOPPE DANS LA COUR J AI COUPE LE CONTACT CAR CELA FUMAIT BLANC AVEC TOUJOURS CE MEME BRUIT DE CASSEROLE. J AI OUVERT LE CAPOT ET LA J AI RECU SUR LES PIEDS LA TOTALITE DU VASE D EXPANSION. CAPOT OUVERT MAPETITE FEMME A REMIS UN COUP DE DEMARREUR ET IL APPARAIT QUE LE BRUIT DE CASSEROLE VIENT D UNE POULIE QUI TOURNE COMME UNE PATATE. A UN POINT TEL QU ON DIRAIT QU ELLE FROTTE DE PARTOUT.
JE PRECISE QUE MA COURROIE N EST PAS CASSEE. J AI REMIS DU LIQUIDE DE REFROIDISSEMENT DANS LE VASE D EXPANSION ET CELA NE COULE PLUS.
MAIS BON LE MOTEUR NE TOURNE PAS ET VU LA TRONCHE DE LA POULIE JE N OSE PAS REMETTRE EN ROUTE
JE NE SAIS PAS QU ELLE EST CETTE POULIE AUSSI J AI UN DESSIN CI JOINT AVEC UNE FLECHE VERS LA POULIE EN QUESTION.
QUI PEUT M AIDER ET ME DIRE SI C EST GRAVE. POUR LA REPARATION ON VERRA APRES.....
CE QUI EST LE C.... DANS CETTE HISTOIRE C EST QUE JE PARTAIS EN WEEK END DANS LES ARDENNES CHEZ LES PARENTS DE MA PETITE FEMME..... JE VOUS EXPLIQUE PAS.....
MessageSujet: Re: [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3   [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 EmptyMer 13 Juil - 20:57
[résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 Courro15
MessageSujet: Re: [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3   [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 EmptyMer 13 Juil - 20:58
MERCI POUR TOUTE L AIDE QUE VOUS POURREZ M APPORTER
AMICALEMENT
STEF
MessageSujet: Re: [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3   [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 EmptyMer 13 Juil - 21:53
Poulie pompe à eau ...
Ce qui justifie l'échauffement que tu as eu.
=> pompe HS
PS : STP, évites d'écrire en majuscules ... Merci
SVP : Pensez à faire un retour d'info ... __________________  [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 Sans_t10 - [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 Sans_t11 - [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 Attent10
MessageSujet: Re: [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3   [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 EmptyVen 15 Juil - 16:15
Merci pour la réponse, la pompe à eau est démontée, les ailettes sont completement voilées et commencaient à attaquer le corps de pompe.
La nouvelle est commandée chez Mister Auto.
Je remonte dés réception.
Je vous tiens au courant
PS: Désolé pour les majuscules...............J'ai pris note
Cordialement
Stef
MessageSujet: Re: [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3   [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 EmptyVen 15 Juil - 18:13
je voulais te répondre a ton mp mais tu as trouvé la solution
MessageSujet: Re: [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3   [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 EmptySam 16 Juil - 8:13
Meca,
peux tu me dire si selon toi, cette rupture instantanée aurait quelque chose à voir avec le passage à l'ethanol?
Cela deux semaines que je roule 50/50. SP95 et E85. Moi je ne pense pas mais ma petite femme m'a dit: Pose la question à Mecanovi, lui il te dira......
Merci de ta réponse, histoire d'en avoir le coeur net.
Amicalement
Stef
MessageSujet: Re: [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3   [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 EmptySam 16 Juil - 8:41
La question ne m'est pas adressée mais l'éthanol n'a rien à voir sur la pompe à eau.
A moins que tu en ais mis aussi dans le circuit de reffroidissement lol!
MessageSujet: Re: [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3   [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 EmptySam 16 Juil - 10:25
merci de ta réponse Eug87, je posais juste la question à Meca, mais je me doutais que cela (te ou BUZZ) allait faire réagir.
Et, sois sans crainte, je n'en ai pas mis dans le circuit de refroidissement.
Mais on a deja vu de tout................... Suspect j\\'ai fait une c..
Amicalement
Stef
MessageSujet: Re: [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3   [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 EmptySam 16 Juil - 10:40
l'ethanol n'a rien a voir avec ta pompe a eau
c'est une coincidence
ça me fait plaisir que tu es confiance en moi
MessageSujet: Re: [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3   [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 EmptyMer 20 Juil - 20:51
Pompe à eau remontée, le V6 tourne comme une horloge.
Merci Eug87 pour la petite info.
On peut fermer le post.
Amicalement à tous
Stef
MessageSujet: Re: [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3   [résolu]URGENT!!! POULIE QUI TOURNE DE TRAVERS SUR S2 3.3 EmptyMer 20 Juil - 22:41
Merci du retour et bonne route. Wink
» URGENT casse poulie damper (résolu)
» URGENT recherche aide ventilateurs radiateur ne tourne plus
» urgent : poulie damper S2 Td 95
» urgent!!! comment demonter la poulie Damper
» (RESOLU) Tourne comme une patate, puis cale...
