[Vous devez être inscrit et connecté pour voir cette image]- 3,498 cc 3.5 liters V 6 front engine with 94 mm bore, 84 mm stroke, 9.8 compression ratio, overhead valve and two valves per cylinder LX9
- Unleaded fuel 87
- Multi-point injection fuel system
- 25 gallon main unleaded fuel tank
- Power: 149 kW , 200 HP SAE @ 5,200 rpm; 220 ft lb , 298 Nm @ 4,400 rpm
