Voilà ce que dit le manuel d'atelier pour la boite manuelle A-598
SELECTION OF LUBRICANT
The A-598 manual transaxle uses SAE 5W-30engine oil, meeting SG and/or SG-CD qualifications,as the factory fill lubricant. G5 SAE 10W-40 engineoil is a suitable service fill alternative.
Hypoid gearlube, manual transmission fluid, and/or auto-matic transmission fluid should not be used inthis transaxle.
Hard shifting effort, bearing, gear,and/or synchronizer failure may occur if incorrectfluid is used.
Si c'est celle là que tu as alors mets de l'huile moteur 10w40 ça ira très bien.
