599 €
 PROCEDURE DE PROGRAMMATION DES TELECOMMANDES
CORVETTE
Nouveau venu
Nouveau venu
CORVETTE
Nombre de messages : 7
Véhicule (modèle cyl année) : VOYAGER 3 - 3,3L V6 - 1998
Spécialisation auto : Jamais mis les pieds chez un garagiste.
PROCEDURE DE PROGRAMMATION DES TELECOMMANDES Empty
MessageSujet: PROCEDURE DE PROGRAMMATION DES TELECOMMANDES   PROCEDURE DE PROGRAMMATION DES TELECOMMANDES EmptySam 11 Jan 2014 - 11:10
Bonjour.
Je cherche la bonne procédure de reprogrammation des télécommandes.
J'en ai trouvé 2 sur les sites US - Aucune ne fonctionne. Modèle 1998 - 3,3L.
PROCEDURE 1
1. Turn ignition to run position (as far as you can go without starting engine).
2. Using any Working remote, press the UNLOCK button for 4 to 10 seconds.
3. Within the specified 4 to 10 seconds, continue pressing the UNLOCK buton and press
the PANIC button for 1 second and release both buttons at the same time. A chime will
sound within 3 seconds to indicate that the vehicle has entered remote programming
mode.
4. Within 30 seconds of the chime, press any button on all remotes to be programmed
including previously programmed remotes. A chime will sound after each remote is
programmed.
5. Turn ignition to OFF and remove key.
6. Test all remotes.
PROCEDURE 2
1. Press LOCK button 5 times at 2 second intervals to resynchronize remote.
2. Insert key into the ignition switch. Turn ignition to the RUN position (as far as you can
go without cranking engine). Wait for ignition chimes to stop.
3. Using the working remote, press and hold the UNLOCK button on the remote for 4 to 10
seconds.
4. Within the specified 4 to 10 seconds, continue pressing the UNLOCK button and then
press the PANIC button ( on the programmed remote ) for 1 second and release both
buttons. A chime will sound to indicate that the remote programming mode has been
entered ( allow 3 seconds for chime to sound ).
5. Within 30 seconds of the chime, press and release the LOCK and UNLOCK buttons
simultaneously then press and release just the UNLOCK button on the same remote.
A chime will sound indicating the remote has been programmed. Press and release
the LOCK and UNLOCK buttons simultaneously and then press the UNLOCK button on
each new remote you wish to program at this time. A chime will sound afer each
additional remote is programmed.
6. Turn the ignition OFF and remove key.
7. Test Remotes.
MessageSujet: Re: PROCEDURE DE PROGRAMMATION DES TELECOMMANDES   PROCEDURE DE PROGRAMMATION DES TELECOMMANDES EmptySam 11 Jan 2014 - 12:09
Ahem... bonjour, commence d'abord par (re)lire ce sujet... ici c'est uniquement pour se présenter
https://www.minivanchrysler.com/t6296-a-lire-avant-de-se-presenter
» Procédure de programmation sur S3 (centralisation)
» Wii fit + et telecommandes
» Trouver des télécommandes
» Programmer ses télécommandes
» telecommandes qui ne fonctionnent plus
